tough brake problem. need some good minds please.
Symptoms: car stops but if you press hard and hold the pedal it will sink to the floor. cannot lock the brakes, even with panic jam. Same symptoms with old master cyl. Could I have two bad ones?
- New rear cylinders, front calipers, clutch slave, master cyl, and stainless lines.
- Bled very well manually and with power bleeder
- Booster holds vacuum
- Tested vacuum booster line and check valve
- Good seal between master cyl and booster
but before doing that,I would re-pressure bleed again. This time lightly tapping the M/C with a hammer. Just a thought...
Hi,
if your brake system is not leaking fluid and there
is NO fluid loss, then the master cylinder is not
working properly. the symptom that you reference
is the exact same as a faulty master cylinder.
good luck
stone
stone racing co
take her out; put it on a "bench" fill the resivoir up with fluid and get all the air out -- much like you said.
I had this same problem with my car after doing the big brakes. I didn't bleed the master. What happened was that it eventually bled itself as I had two rear wheel cylinders that were bad and leaking, somehow, they allowed the master to bleed over a few days, but I would bench bleed the second time around for sure.
IF THE REAR BRAKES ARE OUT OF ADJUSTMENT , THE SHOES WILL HAVE TO TRAVEL FAR TO MEET THE DRUMS . THIS CAN
TAKE A LOT OF FLUID AND NO REAL BRAKING WILL OCCUR
UNTIL THEY DO . THE PROBLEM MAY BE THAT SIMPLE .
I screwed in a bunch of bleeder nipples in each port & ran a little plastic tubing back up to resevoir & cycled the M/C a few times. I did this for each port. Ialso kept tapping lightly with a 20 LB sledge hammer (just kidding on the weight) Then I plugged each port I installed, very messy & DO NOT get any fluid on paint!. mount m/c, pull 1 plug at a time & screw in line. you will let some air in but that should shoot down the line to each slave. if that does not work, get a new M/C or try a Tii M/C or one from a 528
HTH John L .....Philly PA
If you can, you have air somewhere in your system (or your rears are out of adjustment as RIMSPOKE suggested).
If you can't you have a leak somewhere. Have you checked that your booster isn't accumulating brake fluid?
Cheers!
John N.
you've got to bench bleed the master cylinder
go to a good auto parts house (Napa or equilivant) and buy a M/C bleeder. It's a sirenge type of device that you fill up w/ b/fluid and pump it in and out of the m/c until there's no air.
then when you bleed the system don't let the m/c get empty.
