2002Tii Clutch Slave Cylinder Removal
chuncomunco
I cant remove the clutch slave cylinder from the tranny. I already took off the 2 circlips and i've been using a mallet to bang out the clutch but it moves just a tidbit.
Am i missing a step? is there something else i need to remove?
(2760940) 1972 2002Tii Agave, Supersprint Headers, IE SS Exhaust, BMP SSK, Crane XR3000 w/ MSD Blaster, IE 284 cams, JB Racing Aluminum Flywheel, Seral 13x6
I assume you are talking about the 4-speed slave cyl and not the 5-speed.
you've got to work it back and forth quite a bit to get it out. Be careful as the housing (bellhousing) is brittle and it can crack. You have dis-similar metals and they corrode. Take your time and work it back and forth and it will come out. It was easier when the transmission was out of the car - but in the car use an emory cloth or sandpaper on the exposed bits so when you get things moving you won't have any more resistance from the rusted iron.
HTH,
TJW
E36
I was fortunate enough to have my slave develop a leak that saturated the mounting/slave cylinder. Seems that this freed-up things and mine slid right out. Maybe try this?
Later
Lee
