Orange 1976 2002 in NC
Price: $21900
Description:
Killed the original ad and relisting here with some updates, and a bargain basement price.  The current owner has some big changes going on in life, so this car is either going on to a new home shortly, or going into storage.
1976 BMW 2002
Stunning, rust-free example, now available after a 4+ year comprehensive rebuild of the car body, suspension, and drivetrain.  All the right bits and goodies; 5-speed, LSD, Recaros, and fuel injection!
This 2002 was taken down to bare metal, all rust repaired, and completely resprayed in orange.  Every piece of hardware on the car has been replaced or re-coated.  Many new parts and upgrades installed as the car was re-assembled, most with receipts and paperwork to match.
In the engine bay:
Rebuilt M10 with windage tray, ARP head bolts, fuel injected with Megasquirt.  Ford EDIS coilpack set-up.  Carbon airbox, silicone intake hoses, custom adjustable throttle linkage.  Entire engine bay harness has been tidied and re-loomed.  Aluminum radiator, electric pusher fan, all new coolant hoses.  Blunttech headlight covers.  Top-End Performance shorty exhaust header.  Wideband 02 sensor added to downpipe.  Beautifully powdercoated intake manifold and valve cover assemblies.
Underbody/Suspension:
Subframes and arms were blasted, then painted/powdercoated.  All new bushings, ball joints, steering and suspension components installed throughout with new hardware.
Koni adjustable struts front, Bilstein's rear
IE Stage II lowering springs
IE Swaybars front/rear
New strut mounts, bearings, dust shields, bump stops
IE poly control arm bushings
IE poly radius rod bushings
IE solid rear subframe mounts
IE poly trailing arm bushings
New brake hardlines
SS brake hoses
Drilled front rotors
New brake pads
New drum shoes, wheel cylinders
New differential mount bushings
Rebuilt cv axles
Rebuilt steering gearbox
New tie rods, adjusting sleeves, drag link, etc
Other driveline details:
G245 5-speed conversion with TEP 5-speed x-brace, Blunttech DSSR shifter and all new bushings and hardware.  Transmission fully re-sealed.  Rebuilt driveshaft, connected to a Korman-built 3.91 LSD.  IE Stainless exhaust system.
Interior:
Recovered E21 Recaro seats in quality leather, perforated centers
Recovered rear bench seat in perforated black vinyl
New black carpet
New headliner
New sun visor pair with hardware
New REPA seatbelts and receivers
Recovered front door panel set (Aardvarc)
IE billet window and vent window cranks
Koogleworks long console with Glowshift gauges, USB and charging port
Bluetooth media player (not wired)
New polished door sill set
Leather-wrapped dashboard
Custom gauge panel set-up using a few different year gauges
Carbon fiber gauge panel overlay
Rebuilt pedal box
IE billet gas pedal
Recovered rear parcel shelf
New/recovered trunk boards
TEP rear brace with battery relocation
The leather-wrapped dash is, in my opinion, the only let down on the interior of the car.  Notoriously difficult to do, the dash has a few wrinkles and exposed folds, though is still far more attractive than the average cracked dashboard.  Lights all function, as does the heat and sliders for the HVAC.
The fuel tank has been cleaned and painted/coated, and the correct fuel sending unit installed for the fuel level gauge to function properly.
Exterior/Body:
New stainless belt-line trim and hardware
New euro front turn signals
Side markers shaved front and rear
US license plate/light bracket holes shaved
Short euro rear bumper with license plate lights
Hella H4 headlights
Hella fog lamps (not yet wired)
New windshield seals and lock trim front and rear
New window scrapers
New stainless rocker trim
Misc new trim/seals (B-pillar, door handle gaskets, etc)
Flawless front grille set with black center kidney
Misc
There are a few items that could be addressed to really make this car a show-worthy candidate.
The paint work was extremely thorough, but the car has yet to be wet-sanded and polished.  A small section on the driver's upper door was done as a litmus test, and the result is as beautiful as expected.  The rest of the car needs the same treatment to have the luster and depth of shine that it deserves.  The rear bumper needs fiddling with for the sides to sit a bit more even/flush with the body.  Though most of the rubber on the exterior of the car are new, the rear pop-out window seals are not, and are showing their age.  The tachometer has not been wired to work with the Megasquirt.  All other gauges do function, as well as the additional gauges in the center console. The shifter console is loose currently, which causes some up/down slop in the shifter.  The Koogleworks console was left loose so as not to damage it until the bolt is addressed.  The shifter related parts all appear new, so it should just be adjusting/tightening up the hardware to resolve the issue.  There is an oil leak present coming from the back of the engine; likely the distributor housing, but needs to be tidied up and properly diagnosed.
Overall, this is an unbelievably straight, rust-free 2002 that could be used and enjoyed as-is.  The perfect candidate to personalize with a few touches like wheels, bumper/airdam, and any other small touches you see fit!
This car is being sold on behalf of it's owner, with a clean North Carolina title, over $20k in receipts, and several totes full of new/used/spare parts.
$21,900 firm
No trades
Located in Raleigh, NC
Additional photos, and maintenance records available upon request.
This topic is now closed to further replies.
