1.6 /1.8 ltr cylinder head
stephers
Price: $400
Description:
This is from an Euo 318        Dated 84       It has the smaller ports and same size valves as a 1600.     Also has the boss area drilled for a mechanical fuel pump        Head is 129mm thick      Will require a rebuild      Comes with valves, springs and retainers.            Good head to use for n early car     Does not include shipping
Thanks, Rick
Interesting head, I believe it was also used on the e21 316. Both, the intake and exhaust ports are identical to the earlier "118" head on the 1600-2 and 1802. However, the combustion chambers are different from the "118" and appear larger. So, you probably need to use the specific pistons designed for these combustion chambers.
  • 3 weeks later...
