Rebuilt 3.91 Limited Slip Differential
RussTii
Price: $1350
Description:
Completely rebuilt 3.91 LSD. Early unit with 8 mm bolt holes and the correct spacing so no need for redrill/spacers/longer bolts. Unit will be a direct bolt in replacement for any short neck 2002 differential. New races/bearings/seals/fasteners/crush sleeve. LSD unit is a 25% EIMG_0854.JPG30 derived item with good breakaway torque. E21 rear cover will be provided so upon receipt you will swap your 2002 rear cover and add your LSD fluid of choice and install.
Unit will be shipped dry via Fedex Ground with a crated weight of #75 from zip code 30043. Gezon@aol.com
73 2002 Tii Sold
71 2002 Ti Vintage racecar
84 BMW 325 E-Prod racecar Sold
  • 1 month later...
