Petronix ?'s
Can I use trhe stock coil with a petronix or must I get a blue/red coil. What about the ballast resistor if there even is one? The distributor is #0231168024 Thanks for any feedback appreciated
yes! you can use the stock coil. we have the pertronix and used it with the stock coil with no problems at all.
good luck!
obin
Yes, pertronix can be used with stock coil. I used it on mine before I upgraded to the blue coil. Regarding the resistor, If you do upgrade to the blue coil you would just disconnect the resistor.
