Stalling
Just hoping that somebody may be able to help me out with a stalling
problem.
Car starts up just fine and idles ok. After a minute or so everything
nearly shuts down but if you get on the gas pedal things are ok again
for another minute or so and then everything repeats. When all this is
happening I can see that the inline fuel filter (immediately before the
fuel pump) is not full, actually it is nearly dry.
What I've got and what I've done.
'72 02, weber 36 (just rebuilt), brand new fuel pump, pertronix
ignition, brand new cap, rotor, plugs and wires. I've looked in the
screw off filter on the carb body and looked inside the fuel tank, as
best as I can tell neither of these seem to have anything blocking/in
them.
Vacuum leak? What's a good way of checking?
I believe that it's the electric choke. It has a single
lead wire connecting to the cover. In any case it is
not connected and I'm still having stalling
problems regardless of engine temp.
