And speaking of starters....
While I try to decide if an e30 M3 starter is worth it....
What are the opinions of those that have converted from the stock one? I'd like to know before I jump one way or the other. I've read some of the past posts. Just looking for current feedback.
Is it worth it? It looks like it will be ~$100 more to go M3 vs stock....
Opinions?
Thanks
Kevin
s14 starter, but will spin your engine a lot longer with out over heating if you have a hard start, it's cheap and you can put you stock starter back in the box and return it for the core. It weighs more than the M3 but its pretty close to the OME starter in weight so unless you've reduced all the other excess weight go for it IMHO.
it cost me 120 bucks, =/-, because i did not submit my M10 starter as a core. a Karma thing with me. I have been very impressed by this starter: it is lighter and stronger than M10 starter. It also turns a high compression engine over without trouble. I think it is worth the extra money. here are a couple pics of the M3 Bosch starter new/refurbished= as they come from Bosch supplier.....standard.jpg.......and another view......standard.jpg.......and your exact model number for ordering purposes......standard.jpg..... have fun: enjoy the power.
they are same weight and have more power. I've
seen a lot of 530's at Pick and Pull, don't waste
your time pulling the head though....
