What cylinderhead did I just buy and what chamber volume?
I've bought a cylinderhead with holes for fuel injectors (they
weren't open yet when I bought the head). It has an '80' mark
and says 1.8i, but I only know e12, 121, etc. What head is this
and what should the chamber volume be?
Thanks,
Hugo
The head is known as 1.8i & has 63 cc chambers.
In the USA, this came on the E21 3 series cars.
I like using the head, but for carbs it's best to plug the injectors in a manner that leaves the port wall flush.
BEAUTIFUL WORK - I LIKE THE ROLL PIN TO MAKE
SURE THE PLUG DOES NOT MOVE .
I HAVE A 1.8i HEAD WITHOUT THE INJECTOR PORTS , IT
CAME FROM A 318i . I THINK THE ONES WITH THE PORTS
CAME ON LATE 320i E21 CARS .
It has no injector holes and has (if I remember) same volume as the head from the e21. Not having injector holes to plug means less work to do.
larger combustion chambers, to bring total compression down a bit for crappy ca. gas. also, they tend to have less plug thread damage, and they are younger than the typical M10 heads, therefore usually cleaner internally: not need to change plugs as often on those engines. here is a picture of mine: 1985:.....standard.jpg......standard.jpg...... ( this is from MM for the 2.2L engine)
This head was bought new back when they were current production, predating the E30 by a year or so. At the time, it was the best way to achieve what I wanted. It was fresh out of the box then bored out to accept a big journal Schrick & a few other tricks for my 10.5:1 1976 M10.
When the E30 318 head became availabe later on, it came with a higher list price. They remained over $200 more expensive for aftersales when both models ended production.
Of course, either one can be had used, and that's probably the way to go for experimenting!
The injector bungs are already the right size and shape, and you get the fuel rail and a place to mount your fuel pressure regulator (its also very easy to find different pressure regulators).
Cheers!
John N
