318 distributor in 2002
You need at first to change the gear because the distributor on a 318 rotates counter clockwise.
You need the ignitor module with the wiring, and of course, the distributor itself.
Better the go with a 320i module, less wiring.
Pat Allen
If the distributor has a mechanical advance mechanism, it won't work right if you change the distributor drive direction. As the RPM goes up, the distributor will retard, rather than advance, the timing.
Mike
