making camber plates?
This has been discussed a couple of times before, and the general consensus was that if you had dimensions it would be trivial to come up with camber plates, but it's not trivial to come up with dimensions.
If you have access to a milling machine then I would think that doing adjustable camber plates wouldn't be too bad either. Again, the dimension part.
Go for it, let us know what you find!
as the spring hits the inside of the fender after about 1/2 degree.
As to adjustable, yea, it's easy- until you try to figure out the bearing you need to let the top swivel...
