Fix dimmer switch?
I just put in a turn signal switch I got on ebay, to fix my high beam problem. Basically, the high beams would not go on, though they would flash if I pulled the stalk toward me. Now, I have the opposite problem; the highs are always on; it seems this switch is very sensitive, if you hit a bump, it toggles the brights on. Has anybody ever fixed this situation? I can't figure out how to open the switch to figure it out (like I did my flasher relay for example). I really don't want to buy a brand new one ($100 or so) if I don't have to...
THANKS!
I know, but sometimes you have to bite the bullet and get a new one! Hey Give bimmer what she wants for Christmas Shes giving you a hint.
position is either weak or broken. E-mail me offline and I'll look at a spare one I have tonite and see if I can spot something that might be wrong...
cheers
Mike
. . . you might learn enough to fix the eBay switch. Combine parts to make one good switch. I took one apart awhile back but the nylon plastic part was in pieces, which = junk switch.
... coincidentally, I thought of the same thing. Basically I drilled out the two metal studs that appear to hold the whole thing together. It's dirty, but nothing appears broken. I'm going to try to clean it up really well, then epoxy it back together or maybe some small screws. Pretty amazing they get $100 out of these things; there really isn't much to it. Also, it would be better if it wasn't more or less permanently sealed!
THANKS
