woo-hooo!! 45 dcoe!!
just got my single 45 in place with the lynx manifold, still figuring out the tuning, but this is a great piece. I'm not sure what I think about the cable linkage yet, it seems extremely sensitive, and has a really light touch (pedal 1/2 way down is full throttle) and the return is a little slow. but overall went in pretty painlessly, only had to throw tools twice.
that the spring on the pedal box is still on (it is on the same pole
that the throttle lever is). This spring helps bring the pedal back
to 'off' position.
hth,
Dewar
its there but its age is unknown. I'm pretty sure Moses was the original owner, and you know how he was about vehicle maintainance.....
If the throttle is too light for your liking, you can put another
spring (home depot, parts store...) at the top of the throtle linkage
(by manifold -- it just need to help pull the throttle closed). This
should also help the peddle come back a little better. I had to do
this just to get my revs to come back down in a reasonable
fashion between shifts. Experiment with different springs to get
the right stiffness.
hth,
dewar
It is located at one end of the throtle shaft with a notched spacer. I am trying to order that specific part for my old but rebuilt 45s...
That goes in the rear of the carb right behind the acc. pump piston? the spring is held on top with a little brass disc with 2 slots to hold the top of the spring and the bottom goes to the throttle shaft, This is a real good thing to have on all DCOE's incase of linkage failure ect. to shut down the throttle, these are still avalible let me see if I can dig up some part numbers....Marty....
Per Top End drawings parts are #50 spring, part # 47605.012. and #51 spring anchor, part # 52210.006. These can be installed with the carbs on the car with a pair of needle nose pliers and some patience, again for those not running them I highly recomend them, unitended WOT with duel webers is impressive and very scarey....Marty.....
I guess you are talking about the spring hidden behind the accelerator pump cover. Nop. Some DCOEs have an extra return spring located at the end of the shaft, along with an anchor plate. Exactly like a 40 or 44 IDF.
Check the cover from Hayne's Weber manual.
Looks like its another way to do the same thing, I do thing its important to have some type of spring that works directly on the throttle shaft not thru the linkage to shut them off incase of failure, something most aftermarket weber aren't fitted with....Marty...
That seems like a much better fix. I just rebuilt my 45s, but didn't
take the throttle shaft and all that business out. Do you think you
will have to reset the throttle position when you install the spring
(i.e. take the carbs back off the car)? Not sure how that business
works. My car has always idled high without a spring of some sort
pulling the throttle linkage back. Had to go with a lesser tension
spring on the last install to keep from putting a huge strain on the
accelerator arm (for some reason... all parts were the same), and
the idle is back up a bit, although it does come down correctly
after revs.
Dewar
