what keeps fuel from backing out the plungers and inside the
looking at a schematic and some other literature I
see the plungers inside a small cylinder with
passages, but there is no seals or anything to
prevent the fuel to just "fall" inside the pump where
the cone and the cam are located. I know that the
fit is tight but 500 psi hydraulic pressure is hard to
keep from leaking, what is the secret here?
Michael
72 tii
I don't know for certain about Kfish, but Alfa SPICA injection pumps are similar, and the fit of the pump piston in the cylinder is the seal. It's really, really close tolerance.
Tony
When the Alfa ones wear and leak, your crankcase smells like gas because the pump uses the engine oil supply also.
Is the k-fish the same?
