weber 32/36 trouble------btw ive done a search already
ive been having trouble with my 32 36 dgav. it used to be part of a dual setup on a 2800, so i dont know if it needs rejetting or anything like that. if it does need rejetting, can that be done by just a screwdriver, or will I be needing a rebuild kit? ive got a 76 2002 with some 8 mm wires as my only other upgrade. other than that, stock. help is appreciated. thanks
You'll probably need jets. The 32/36's I scored off of a 240 Z had very small jets compared to the 2002. - A kit is just good insurance, since you'll need a few gaskets anyway. And I've had trouble with needle valves...
What jets, you ask? THAT will come up in a search- I'm a 38/38 consumer myself, so I don't remember the 32/36 range that works...
and it was actually the idle adjustment on the back of injecetion pump. It had gotten greasy and some how got closed so the car would not idle w/o gas. This is a butterfly type piece on the back of the pump, under the fuel lines. See if this may be stuck in an incorrect position.
