So who actually put a 265 tranny from an M3 into
their '02?? What did you do as far as the crossmember is concerned? Also looks like the center bearing mount needs relocating. Just looking for some tips..I know I will have to widen the tunnel. I just want to exhaust all the options on using this tranny before throwing in the towel and forking $1500 for a modded 320i 5 speed and shortened shaft. THANKS!!
which has the integrated bellhousing, crappy aluminum shift forks, etc... The 265 is the"big 6" tranny that was adapted for use with the S14. Some big sixes also use the 260 though, but with a different bellhousing casting.
Matt
hooked up to an S14 but it's PO installed and I've never taken a hard enough look at the bracket to try to figure out where it came from. I'll try to look at it tonight and report back.
