Help: I got a Line on a 76 3.0Si
Can be had for under $500, it's supposedly
straight and in decent shape vis-a-vis, rust.
However, major tranny issues....namely, no reverse.
Am I crazy to consider this one?
Pro's/Cons....any & all advice wanted.
Jerry
You'll want a five speed anyway. Grab it if it doesn't have rust everywhere!
Owned a bunch of E3s(13).... hopefully another one shortly. Is it Automatic? Check for all the same rust spots in an 02.. It is desired to have a later model cylinder head (82 and newer), older were prone to overheating and cracking due to insufficient coolant passages. I had a 72 head which was rebuilt and had no problems. Used heads can be had for about $100. 5, 6 and 7 series cars are great donor cars. check out the link for the Senior Six Registry. Great underrated cars...
You cut, I replace the Tranny. Sounds like A plan to me. As soon as this Darn rain/snow stops.
Andy
I bet you're talking about the one in central Oregon, right?
Anyway.. the 3.0si's are not very loved cars. Sure they are a decent ride and all...kind of big and wallowy in their own way. The BMW 2800 and the Bavaria are it's relatives and there seems to be a very small cult of die hard guys that hanker for them. I kind of like the style. I also own a project 2800 (I bought for $300 with a bad engine). Mechanically it's all pretty straight forward and is simiar to a 2002 in many respects (albet with 4 doors and a 3.0 liter 6).
Go get it. If you need an auto tranny I have several sitting..... for cheap. I'm only 1 hour from Portland, OR.
WH
Thanks for the tranny offers.
We'll see how it all pans out.
Jerry
slightly larger version of the 02 flag mirrors--could be a neat addition to an '02 if you could find a pair...
I have always liked those Senior Sixes. Should be a great car for just cruising along in stylish comfort.
Show us pics once you get it!
All the best,
Harry
URL: http://www.geocities.com/MotorCity/Downs/9271/e3guide.html#rust
The one in Redmond... Trans is 3hp22, usually reliable. Also readily available for not much $. Many parts interchange with e12 5er's. Early L-jet, no 02 sensor (doesn't run quite as well as the later verion). Don't think this would have the thermo-reactor exhaust, but not sure -- check that, because that's a head killer. Can be replaced easy enough with regular manifolds and downpipes.
Check out the link for more buyer-beware stuff. I disagree with the AT thoughts in this link, as I said, used AT's are pretty easy to come by and the 3hp22 is pretty reliable with normal maintenance. And swapping to a 4- or 5-speed is a pretty easy job (way easier than a 2002 5-speed swap).
Tony
