Follow up on E3 or E9 spare tire well:
Don't think so. If you were to increase the diameter of the well
you would have to run a smaller muffler and/or trim the left
rear quarter panel to accommodate. And, with big bumpered
02's there is a larger center frame member which limits the
spare tire well diameter further.
IMHO, it's not worth the trouble. Stick to the 02 well, just make
it deeper, if need be. In fact, why not just keep the original
size spare??? it's just a spare, right? I would actually like to
find a "pizza cutter" spare for my 02. Then I could put more
tools and "spare's" in the spare well.
-E
Geeze tman: everyone is going to 20s and bigger- you gots to get with the timeze...Thanks E for the info: actually,i think you are right about the concept of a smaller spare and some extra space. Guess it boils down to how much driving and the preformance you want from your spare. Hell, i should just get a 13 inch lightweight wheel. But, i have a lot invested in my Alpina turbine spare and new rubber, so i will just have to live with it. It is the size of my other tires and it clears the front calipers, so I dont need to do a double switch if i have a front flat, and i can drive at speed with it on the car. Thanks for your opinion on the E3, E9 swap out.I guess the projects went well. I am still trying to line up a recaro adapter for driver's seat, but i need measurements:I had a lengthy exchange with a nice guy with rails from s set of flowfits, but they only raise the seat 1 inch and i think driver needs more than that. email me off board for ideas on solving the recaro bracket issue. Thanks again for your work. Did you find the spray paint?
in reference to the original post, "j 71 Sahara,j 72Inka tii A4"
had indicated that he in fact needed an increase in the
diameter of the 02 spare tire well and that Carl Nelson had
indicated that a larger diameter well from an E3 or E9 might
be used to give him that additional diameter.
Also, 5% of the original 165/70/13 wheel diameter is close to
1.5" total. And if you had additional tire width (which in
most situations would be the case), this would make the
spare tire ride higher up in the well (thereby pushing the
trunk floor boards up) due to the combination of total width
and the larger diameter tire riding higher up on the transition
radius between the vertical wall and horizontal floor of the
spare tire well.
I am saying that, in my opinion, the E3 and E9 wells would be
a big hassle to fit up and probably not worth the effort.
We clear on this now?
-E
Most modern tires NEVER go flat unless threadbare or you pound a curb or drive through a mess of nails. In that case just throw the regular spare on and drive home. Plus, why spend and additional 20% on tires/wheels just to haul one around in the trunk? If you're gonna do that, then spring for the Continental kit... ;-)
