car still in shop...
URL: http://cruiserco.com/lance_hawkins_fj40.htm
I took my car to a new shop and they are still a bit baffled by the
problem. As I posted before, the car misses at higher rpms. Now
it revs great and you can't even tell anything is wrong until you
take it for a drive. Under load is the only time it really cuts out.
The mechanics put in a tii distributor with points and condenser
with a blue coil and the problem still persists. I went through the
carbs and cleaned all the jets and made sure nothing was gunked
up. Also made sure idle mixture and side-to-side adjustment for
the dual 45s was right. I guess all indications point to something
in the motor. Hopefully the mechanics will figure it out tomorrow,
but does anybody have any clue what the hell is going on?
thanks again,
dewar
p.s. pictured is my roommates car that i am riding around in until
mine is fixed. 66 fj40 with a vortec 350...awesome. link shows
complete conversion that po did
URL: http://store.summitracing.com/productdetail.asp?p=309
With this Volvo B-20 that i built with cam ported head and duel
40's. I was trying to get by with the mechanical fuel pumf figuring
that the pressure might be low but the flow would be ok since the
car originally had duel SU's. I recently installed a Carter P4070 (49
bucks at Summit racing) fuel pump and it cured all the problems I
was having sorting out the webbers. I have heard that you should
use this pump only with side draught Webbers , and that the little
Facit type vibrating pump is just not sufficent. I used to think this
was bull because the last motor I had in my 02 used the same
40's and a Facit type electric pump. But now that i look back at it I
did have a stumble intermitently above 6500 RPM. I'm sure i
wouldn't have had the problem with the Carter 4070.
Highly recomended!
john
Revving in neutral opens the throttle very shortly and
requires little fuel. Opening the throttle under load requires a
lot more. The fact that the mixture is correct at idle is no
guarantee it will be right under load. I suggest rolling-road
session, or fit a lambda sensor with readout for starters.
Good luck,
Hugo
tried substituting new spark plug terminals--the long bakelite things? They've been known to go bad since they have radio suppression resistance built in... Just a thought. But it does sound like high-speed fuel starvation...
Mike
ya gotta figger out which!
I use the cheap 02 sensor setup- if it's spark, it'll stay happy, with maybe a quick stutter in ratio.
If it's carbs, the mix will go massively lean (or maybe rich) but it will do so over a longer period of time.
Then you can diagnose from there.
The electrical faults will 'usually' be more abrupt than the carbs, but I had a partially- failing condenser once that felt EXACTLY like a mid- throttle lean- out...
fwiw,
