bouncing drive shaft
Actually I should have said go to the left side and pull. I thought since the problem occurs during right turns possible the right mount is busted and the engine is rocking to the left.
and the tranny mount was retighten when i rebuilt the motor last month. i'm totally confused why it's bouncing around. thanks for the suggestions. i'll recheck the motor mouts and tranny mounts. appreciate the help.
thanks,
evan
Last week I found that the nut had come off of the left mount and it was free to move around. I had some vibration during hard turns and I just thought after your post that it may have been caused by this.
there is a natural amount of M10 movement on the mounts, but sounds like you are experiencing more than that. take another look at the subrame too: was it weld reinforced ? If that has cracked it could be translating weakness to the mass on top and allowing movement. You have had X amount of "good miles" since the transplant, right? So something has loosened, broken, or gone "weak". also: you can apply some chalk to various spots with known gaps and see if it is present on the sides of the car after test drive. will give you more info as to what part is moving and how much it is moving. Just an idea... it should work. Good luck Evan- you will get it fixed!
Thanks Jay. I appreciate all the input. I'm rechecking the
motor mounts tommorrow and will put my car up on jack
stands to check out the guibo. It's weird that it only seems to
bounce when I'm cornering hard right. Anyways, the
encouragement is always nice and I will figure it out. Thanks
again. Cheers - Evan
