lowered spring perches
hey, anyone tell me what a lowered spring perch is, or have a pic of one? I am driving an 02 that is very hard steering at slow, parking speeds, but handles great at speed. In a pack of reciepts I got with the car it said something about lowered spring perches, wonder if this changes caster as well....
They make 3 different spring perches. Some are simply thicker than others. It is the rubber pad that the springs set on. Thinner ones lower the car.
Tire pressures
The wider the tire, the harder the steering
Brand of tire--some are harder to turn than others
lubricant in the steering box
binding tie rods
sticking idler arm
sticking/rusty upper strut bearings
diameter of steering wheel.
Unless the front end geometry has been drastically altered by lowered spring perches, they shouldn't have any affect on steering effort.
Check it out
Mike
what's the offset of the rims you are using. I had the very same problem and it was due to incorrect offset of the wheels. You need around et30. The lower the number the worse the effect. I had et18 and was developing POPEYE forearms. Went to et35 which is very close to the strut but clears, now velvet handling at very low speeds.
