bought an amp for the stereo, can't find how much amperage
it draws, but I'm a little worried, amp is 50 watts x4 speakers output. any guesses, jeez do I need even a larger alternator that the 65 amp one I've got?
I have a 200W amp and 2 MBquart 6x9s w/a 65amp alternator -have not had any problems. However, make sure you use a fuseable link inline with your positive power. I use a 20A fuse.
and whether the rating is at 12V or 14.4V. What is the THD spec
at the rated power? If <1%, then the power rating is good. Figure
about 17 amps for 200 watts @ 12V and 14 amps for 200 watts @
14.4V. A 65 amp alt. should support that unless you are running
high wattage headlights or some other major power consumers.
Chris B.
'73 ex-Malaga
i run a 200 watt amp, 45 watt head unit and H4s with 80/100 bulbs and 65 watt driving lights on the Sahara without any noticeable drop even with fan on. Of course, i would like 85 or 90 amps, and will have that someday, but you will be fine with your set up. just be sure alternator is in good shape and belt is correct tension. have fun- good listening.
but I have a voltmeter and can watch that, also don't expect to driving around at night with the volume cranked up to the max. now to install everything.
