Guest Anonymous October 17, 2003 I got my 2002 home yesterday after a 45 minute drive, parked the car, and five minutes later tried to start her up again, it would not start, it made a noise that sounded like the starter was turning over very slowly. I tried jump starting but that did not work, i will try again, however i dont know if my battery is completely dead? or if my starter is history? or if my battery is dead, since i drove the car for 45 minutes why would the battery not be charged up some, so my last question is, is my alternator done for? any help would be appreciated. One more thing, how can i check my alternator, to see if it is working? Share this post Link to post Share on other sites
Guest Anonymous October 18, 2003 easiest first, clean the terminal, spend $3 on a terminal cleaner tool at Kragens, move to the starter connection, alternator, etc. Charge or swap batteries. Get a Haynes manual to get you going with basic trouble shooting for alt, reg, starter and battery. Good luck Michael 72 tii Share this post Link to post Share on other sites
Guest Anonymous October 18, 2003 You can pull the battery and take it to your local parts store for testing. They should be able to tell you (for free) if it has a good charge. If it has a good charge, they can test it and tell you if its bad. If the battery is good, look into wiring (connections)or starter/solenoid. If the battery is not good, look at wiring (connections, or something drawing the battery down)and alternator/regultor. Good luck! Share this post Link to post Share on other sites
