clutch pedal box - '69 1600
I need a clutch pedal box, and rod gasket assembly for my '69 1600. I'm in Sacramento, CA. If you have any leads please e-mail me at: extra@lanset.com
Many thanks.
prior to vin 1665200 will work. The first few hundred 02s had mechanical clutch linkages just like the 1600s. Then they modified the 1600 pedal box to take a hydraulic clutch M/C. These are the boxes with the large coil spring and a horseshoe-shaped link that returns the clutch pedal to its rest position. Later pedal boxes use a hairpin spring that surrounds the pedal shaft. If you can find one of these early boxes, compare it with yours...it may be adaptable.
Cheers
Mike
