Anyone out there using a turbo resonator? I did a test fit
this afternoon and discovered that sucker is MUCH bigger than stock (the metal "O" ring will fit inside the pipe for the turbo resonator).
Do I just get a larger "O" ring? Have the flange of the downpipe enlarged? Get a larger supply of chewing gum?
Thanks!
John N
At the size of the downpipe on the turbo. If you end up fabricating a transition piece, try to make the length 2-3 times the diameter of the pipe. So which new welder are you going to buy?
