BMW factory cassete deck blaupunkt
I've got a Blaupunkt BMW factory cassete deck in
my car but cannot get the radio code to work. I tried
it many times before I confirmed the code # and
wonder if it is programmed to deny codes if you try
it too many times. Is there any way to reset the
radio? So far I've pulled the fuse. I also left the
ignition on for over an hour but the radio still will
not accept my code #.
disconnect the battery again and try the code again. Are you sure your code is correct, never hurts to double check with the dealer or your old records.
Ratt,
The factory BMW Blaupunkt cassette decks came
with a radio code as an anti theft measure. Each
time you disconnect the battery you have to retype
the code.
Keefer I've checked the code 5 times. The problem
may be that I typed the incorrect code too many
times before I had the correct code. I'm concerned
that I've triggered some kind of lock down on the
radio. What key position should I have the key
while leaving the radio on for 90 mins. I don't want
to burn out my points.
Mike,
You may be on to something. My son's 97 Jetta has a Blaupunkt with security code and the instruction book cautions not to enter the code incorrectly, I think, more than three times. Go to the BlaupunktUSA.com web page. I believe they have a tech assistance toll free.
Earl Myers
74 2002Lux
72 Volvo 1800ES
Yes the radio is programmed to only allow 3 tries.
After 3 tries you need to have the car someplace with the key in accessory and the radio on for at least an hour...hour and a half works better.
When you start to input your code...if it beeps at you before you input all the numbers, stop and start at the beggining. You get three tries and then have to do the batt thing again.
If it won't take the code after several tries and you have confirmed the code is correct through BMW...the radio is defective
