big grins on the 32/36 rebuild using C.D.'s recipe
Creighton's 32/36 rebuild recipe & Wow! Nice & crisp throttle response! Much better pickup & pull. Gotta check my MPG too. My idle is a litle rough but that is just in the mixture adjustment. I also plugged the secondary course feed and used C.D.'s jet recommendations. I also discovered that I had 45 and 75 mm brass float measurements that needed to be brought back to spec.
thnx C.D.
Wish I did it sooner.
John L
Lafayette Hill PA
