Update on brakes
Car was pulling hard to the right when braking, pulled the calipers, left pads were gone. Replaced left caliper, both pads, problem solved. Thanks for the help
Michael
72 02
If both left and right pads were replaced, I would expect the wear to be nearly even for both sides. A sticking caliper, siezed flexible lines, and I believe low tire could all cause uneven wear.
Of course I could be way off base and just picking flowers.
My guess is that a sticky caliper on the left caused the pads to be gone, so when the brakes were applied there was more grabb on the rt side. I replaced the left caliper and put new pads on both lt and rt side. Probably it would be a good idea to change the hoses too, but there is no pulling anymore.
