tii gask tank hookup?
PS, i know the rubber from the stainless to the tank sorta defeats the purpose.. but $$$ is a big factor here unfortunatly.
matt
Does anyone have a close up of the top of a tii gas tank? How was it hooked up from factory? I assume hard metal line welded to the tank... then was it just high pressure hose to the hard line going to the engine bay?
i'm trying to figure out a way to connect my stainless steel fuel *feed* to my tank. (currently don't have a tii tank). i'm thinking cheapeast/easiest is to just use a short piece of high pressure rubber from my AN stuff to the pickup (pickup/sender in this case). I can get a shop to weld/braze a AN fitting on my carb tank, but then i have to pay to get it steamed first (otherwise they won't touch it), and figure out a fuel pickup system. By that point I may as well just buy a Tii tank.
But I don't have the cash for a Tii tank and filler hose at this point :(
thanks
Matt
Sorry it's not a clear picture, but I did have one on file of my car before I started a bunch of work on the trunk.
The newer black gas line goes to the fuel pump. The other line is the return line from the back of the Kugelfisher.
Keith
'74tii-Stella
http://www.my2002tii.com
