negative camber in the rear
Due to how the 02 rear suspension works, it would be tough to make a REALLY nice system, where it is easily adjustable. Irelands kit is good for what it is. You have to drop the subframe and weld the pieces on, and slot the existing holes. The one thing that bugs me about it is that it is hard to adjust toe, due to the limited amount of space. Its really hard to get a wrench in those tight spots. Having said that, there is not much you can do, its not the fault of their kit.
I would do it again. I have my rear end eyeballed for both camber and toe (yeah yeah, I know, I know), and it is WORLDS better than what it was before. The one problem with flipping your subframe mounts is that they move the position of the diff carrier, and hence the diff, so the driveline is not absolutely straight anymore. I HAVE NOT DONE THIS, this is just what the archives say. Guys like Lee have done it in his race car and haven't seen any ill effects, so it can't be all that bad, right?
Matt
'72 02/m20
ps pic is from Ireland, not mine.
