1972 02 Race Project Socal
72roundracer
Decided to sell my 72 project car. I bought this car a couple years ago and just have not had the time to bring her to glory. The car was completely stripped and had some metal work done to clean up any rust areas. Unfortunately, I lack the skills and time to make it look decent. It will need some finish body work and a repaint to look good. To get it running, it is going to need all of the hoses and hard lines, radiator, fuel pump, and oil cooler. I did have an engine shop in La Jolla build the motor, and it was a complete rebuild. I have spent way too much money on this, and am hoping to recoup at least a fraction of what I have put out. I do have all of the titling paperwork, but I never transferred over to myself once I bought it.
Included:
Custom 6pt roll cage
Fuel Safe Enduro Fuel cell
New front/rear brakes
All new bushings and mounts
IE Fiberglass hood and deck lid
Here is everything done to the motor (spent about $5500 on it in total):
M10 block
292 Cam
h-beam connecting rod
racing rocker arm
racing rocker lock
oil pump
CP Pistons - 4 cylinder
Stuff purchased from IE:
Clutch Racing Disc -215mm
Clutch -Racing Pressure Plate -215mm
Flywheel -lightened
Motor Mounts - Urethane for 2002
Transmission Mount - urethane
(2002 1972)
Weber 38DGES (Electric Choke)
Control Arm
Sway Bar Set - IE 22/22
Steering Coupler - Urethane
Rear Race Springs 5"
Sway Bar End Links - Stock 2002
Strut Brace-2002 Stainless Steel
Urethane Bushing Kit -front 2002
Urethane Rear Bush Kit - 2002
Camber Plates -adjustable racing
Front Coil Over - adjustable height
(-2)
Bilstein Front Strut Insert - Short Race
Brake Bias Valve
Exhaust Gasket - Heat Shield
Step Headers for the 2002- steet/race
Canon 2 barrel Manifold for weber carb
Springs - 2.5" ID Racing
(400 x 7)
Bilstein Rear Shock Absorber - SPORT
There is also 3 tubs of various parts that came off of the car that are yours too.
I might be willing to part some of the stuff out, but as of right now, I would like to sell it as one big, happy package.
I can send more pictures if necessary, email me at jonryanevans@gmail.com
Looking to get $7,500 for everything.
Year: 1972
Make: BMW
Model: 2002
