how do I hook up this old Blaupunkt?
I've got this old Euro Blanpunkt Frankfurt radio...think its a mono...but I can't find where the speaker wire is supposed to go...anyone have experience with these old radios?
thanks
dave in houston
....the din connector is supposed to go with the radio but folks in
a hurry pull the stereo often leave the din plug behind thinking it
is part of the car's wiring. A good stereo place may be able to
make one up because it's a pretty simple connector. I have had
this done to other stereos. Give it a shot-you might get lucky.
Pull the cover off of the radio (carefully). You should be able to trace + and - easily. Once you find those 2 wires, the rest are speaker wires, very easy to identify. Go to radio Shack, get some pins that will solder on the end of a wire & fit the hole, and make your own harness. Be careful with the power wires though. Good luck.
Steve P. in NC
thanks for the tip. I removed the top of the radio and the damn circuit board is smack in the way, blocking the DIN. However, I can see 5 wires which are coming out from beneath the circuit board and my guess is these are connecting into the DIN. They are in order, Red, Blue, Black, Brown, Yellow. Now I don't know which wires go where into the DIN.
I thought it was a 7-pin...but I think the seventh is actually some kind of alignment hole. Maybe that makes this a 6-pin DIN?
