heater rebuild
rebuilding my heater. anything i should "make sure" i do before i put it back together??
looking at the fan and not sure what i can do to the motor. seen a couple of comments to lube it but i'm not sure where you lube it and with what.
any suggestions welcome.
thanks.
tim
72tii
When I redid mine I used 3 in 1 oil on each of the
bearings/bushings. If you have the motor out of the
cage, so you can access both ends, simply squirt
the oil liberally where the shaft enters the bearings
on each end. Then spin by hand, or better yet,
hook up to a battery to really work the oil in. On the
end opposite the fan, you may have to remove a
black plastic cap to access the top of the bearing.
While you have it out, make sure the fan is fairly
tight on the shaft (mine was a little sketchy, so I
coated the hub and fan with epoxy). The seals in
your heater box are probably dry and crumbly also.
I used some thin foam I found at a hardware store
and renewed those also. I cut cardboard
templates and then made new seals from these.
Hope this helps. Good luck.
Dave
