how to drop the @#($*FD driveshaft?
So okay, someone give me a 'driveshaft dropping for dummies'. So far.. the front trans guibo is out.. exhaust is out.. and the center bearing is loosened. But it seems as though the 4 bolts connecting the driveshaft to the diff have round heads on the end.. does this make any sense? I can barely get in there with a wrench.. never mind turn it.. PLUS keep the driveshaft from turning (remember, the front is out, so its hard to throw a screwdriver or something in the front).
is there an easy way to this? I'm thinking.. since the car is waaaay up on jackstands.. that if i unbolt the diff, i can probably 'pull' the entire diff/driveshaft out by pulling/snaking in out through the back. it will be close..but i think its doable. anyone done this before? I dont' think there is any way i'm getting those 4 bolts out as it is right now..
thx
matt
Hi,
okay the first is to have someone in the car and
just crush the brake pedal to the floor. then
while they drain the blood from the rest of their
body, you put a 17mm long handle box end wrench
on the bolt from the right side of the differential
and add the box end of a 19mm wrench to the open
of the 17 and push up on the whole mess to loosen
the bolt.
or the way i do it is to put a 17mm wrench on the
nut and then put a pipe wrench on the driveshaft
and spin the driveshaft so that the nut loosens.
the second is easier because you are using the
torque of the shaft to do the work.
good luck
stone
stone racing co
those bolts ARE round-headed! But they are locked on their one flat side against something (i forget what) and you ONLY have to attack the nuts. HTH!
-Rob
Watch the banged hands though. It hurts. Some penetrating oil helps. Once undone keep them clean and when you atack this project in the future it will be 2x as easy.
kris
Well.. brakes are disconnected, so can't do that. the front of the driveshaft is on the ground, and i'm by myself, so can't do that. so i'll have to try to jam something into the rear yoke...although i'll be damned if i didn't try that already and there was no room. oh well, i'll try again.
damn you mr driveshaft, you WILL come out today!
matt
This technique works! (take it from a floundering mechanic -- actually accountant who is too cheap to pay for others to work on his 02 who could do the job in 1/10 the time it takes me!!). Mine took a little longer than 15 minutes but it was not an all day process either.
Use a large spanner on the flat (like a 20/22) and put it under the flange and rotate the flange until it won't turn and is 'locked' in place. Then undo one of the flange nuts. Remove spanner and repeat 3 more times. It'll be out in about 15 mins. (practice helps on this job!)
This is quick, won't damage anything, is a one person job, and you won't skin any knuckles.
Gil
72 Tii
I must be dense today.. I don't get "Use a large spanner on the flat (like a 20/22) " please explain..
matt - founder of dummies 101
