sticky brake pedal
cluna
begining at the booster/brake light switch because it's
the easiest - oil the pedal linkage
vacuum out the pedal box - using a narrow hose-end
to reach into the carpet slot - getting all the cheese
and decades of crud rusting the pedal and pivot - after
de-mucking in there - oil the pedal shaft/spring/ shaft
till the pedal move freely
do the same for your gas pedal at this time
and usually - this question occurs AFTER someone
has 'repaired' something in this area - over tightening
something
