I would like to continue collecting Setup and Performance Da
I want to tie this to the "poll" page somehow... If you know ANY of this information as it applies to your car, please EMAIL it to me so i can start keeping a database and then get it ready for posting.
Please provide ANY of the following information, especially if you are in the "poll" listings already:
Displacement(bore/stroke?):
Compression/piston type:
Head type/mods:
Cam Brand:
Cam Lift:
Cam Duration:
Carburetor(s?) Brand, Model:
Main Venturi/s size:
Auxiliary Venturi (if applicable):
Main Jet:
Idle Jet:
Air Idle Jet or hole (if applicable):
Emulsion Tube:
Air Corrector Jet:
Starter Jet (if applicable):
Accellerator Pump Jet:
Accelerator pump back bleed:
Needle Valve:
(Not ALL of these specs will apply to your type of carb. For example DGAS carbs dont have "Starter Jets", and DCOES dont have air idle jets/holes.)
In addition,
type of header/exhaust manifold:
size and type of exhaust system:
timing setings:
AND PERFORMANCE NOTES: Ever had it dyno'd? 0-60, 1/4 mile times? I cant think of anything else to ask. If you have anything else you think is interesting, relevant, or just f'n worth saying, then please do so! ;)
-Rob (remember please email the info)
