e12 front sway-bar in 02
it sounds more complicated than what I did, but
I had considered the Ireland bar for about six
months, but I'm glad I came across the e12 bar. There's plenty of room for the crankshaft pulley as the bar sits below the front valence - doubling as a front
nose protector.
  • 4 weeks later...
since the 22mm hollow ireland bar i have wont clear the comp. oil pan, im looking at doing something else for a stiffer setup than the 22 solid bar that goes in the stock location that i am going to use as an interim setup. it will prolly be a compromise setup that will pivot at a point somewhere between where the stock bar sits at the front of the subframe and where the ireland one crosses right under the center of the oil pan. cept the stupid engine pulley is right there... anyways, nice work!
-Rob
