I need a clutch alingment tool. Seattle area
It's real easy to do without it. Just put the clutch on with the bolts finger tight. Then sit up under there with your eyeball aligned with the center of the clutch, loosen the bolts till you can slide the clutch plate around, and get it centered. Very easy to get it perfect. Tighten it up and away you go. I haven't used an alignment tool in 20 years.
????You are more brave than I. Your method sounds solid. I have never done this so I would like to have mechanical advantage to fall back on. Just in case.
I only used it because the local auto parts store didn't have one in stock and I wanted to put it together that day. I have an input shaft out of a tranny that I normally use, but it was loaned out at the time. I did keep the sprinkler riser tho!
