FS: Complete S14 and Transmission
Sean
For sale is a complete S14 motor, with transmission and accessories (except A/C parts). Complete from the air filter to the exhaust manifold, including but not limited to, AFM, starter, alternator, radiator, water pump, and DME. Basically the whole package.
Comes out of a 1988 M3, 116,000 miles. Healthy, strong engine that idles well and pulls cleanly to redline. Well-maintained, with 3,000-mile oil changes and careful use/no abuse. Maintenance in last 10,000 miles includes throttle and airbox o-rings, airbox mount, oil thermostat update, valve cover and lower sump gaskets, E36 timing chain tensioner, coolant manifold gaskets, spark plugs. Turner oil pan baffle and hex-keyed header studs. Some minor weepage from front cover but otherwise tight and leak-free. Needs nothing save a valve adjustment; will probably require alternator in next 10-15k, as bushings are a bit worn and alternator bearing a bit noisy.
Comes with original (U.S. overdrive 5-speed) transmission; trans is tight and shifts well but can occasionally be a tad notchy.
I will be able to provide compression and leakdown test prior to pulling motor next week. The package will be available in Chicago at Ben Thongsai's shop in approximately two weeks.
Price is $5500 or best offer. Pickup from Chicago is preferred, but shipping can be arranged at the Buyer's expense. Email me at spleuba@comcast.net . Please no PMs. Thanks.
-Sean
