Compression Check help
rho
I am going to check out a used motor and have some basic questions. I've never done a compression check and need some noob advice.
Will the local Kragen / Autozone carry decent compression testing gauge?
What numbers should I expect from a semi new rebuild with 9.5 pistons and a relatively new rebuilt head?
And finally, what is the best way to test the compression.
Sorry for all the questions,
Thanks
71 2002
90 E30 M3
99 E39 528i
You need a compression gauge it crews into the sparkplug hole. You should remove all plugs and turn the engine over with a well charged battery. I think with 9.5:1 you should be looking at low 200 psi. Where are you located I have a gauge and time in the morning if you need some help.
Robert
Trying to buy back my
75 Sahara
Pertronix, 9.5:1, 294, 40mm Solex, 5 speed, MSD
Robert
Thanks for the info. I'll probably check the motor next weekend... I'm in Alameda. If you are free I'll email you a few days before I go.
Thanks again,
Robert
71 2002
90 E30 M3
99 E39 528i
