Differential parts
Hi, here's detail on the various diff internals and related parts for sale. Happy to see this get used; discount for multiple items. Local pickup fine or will ship out of San Diego, CA for actual cost.
Ring gear/pinion set (H2 = 3.91)    $150
Ring gear/pinion set (H12 = 4.44)    $175
Ring gear/pinion set (H9 = 3.64)    $100 pending
Differential internals (all 168 mm small case, fine spline output for late 02/E21 spline output flanges)
Diff carrier/spool, welded    $75
LSD carrier/pumpkin, 4061004165 case stamp, measured breakaway torque 58-61 ft-lbs    sold
Diff carrier, open, spider gears good, E30/E36? with impulse wheel still attached    $50
Output flanges, all fine spline compatible with above
E21 (one is drilled for M8 & M10 mm CVs)    sold
E36 small case, 33131214077    $20/ea
Input flanges, 27 t spline, fits pinions above
2002/E21    $60
E36/E34? (round style, same bolt pattern)    $20
Side cover, 6-bolt E21, some with bearing race removed    $20/ea
Side cover, large bore 4-bolt, 1212978, E30?    $10
Shims, 6-bolt various thickness    sold
Shims, 4-bolt various thickness    sold
Misc parts, bearings, large E36/E34/E30 6-bolt shim    inquire
Edited by danny_sd
marking sold
  • 4 weeks later...
