Gecko coilovers
DanJer Motorsports
Price: $990
Description:
$100 SHIPPING
$90 Adjustable camber plate option
Street series coilovers have 24 clicks of combine compression/rebound adjustment with independent preload and ride height adjustment.  The valving and spring rates are designed for street and mild track/autoX use.  These also include adjustable camber plates.  Combine these with our wide control arms to achieve 3.5° to 4° of camber.
Your strut body must be cut and these fitted and welded. This should be done by a certified welder.
WWW.DANJERMOTORSPORTS.COM
$100 SHIPPING   Adjustable camber plates as an upgrade!!!!! Street series coilovers have 24 clicks of combine...
Extended Chromoly control arms and other 2002 parts
https://www.danjermotorsports.com
Instagram.  https://www.instagram.com/danjer_motorsports/
  • 3 weeks later...
  • 1 month later...
I get a lot of questions on these about ride and strut modification.
1) they ride pretty good and are not harsh.
2) the fitting of the front strut is pretty straight forward and any local fab or 4x4 shop should only charge 0.5-1hr labor.
