exhaust from oil fill cap
mthaynestii
After adjusting the valves on my 72tii resto, I started her up and opened the oil fill cap to take a look. I am getting a lot of exhaust from the oil fill hole. The car sat for about 10 years before I got it, and the engine was in unknown, non-running condition when I bought it. Right now she idles kinda bumpy, but revs nice. How much blow-by should I be worried about?
Matt Haynes
72 Malaga 2002tii - Moes
81 Toyota Supra - Cellie
91 Alpinewies 325iC - Ilsa
07 Titansilber 530xi Sport Wagon
Thats not exhaust, it's crank pressure and unless it is real excessive it is normal to have. Even ,my brand new M10 motor Thats why it has a baffle breather at the top of the valve cover
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
The blow-by coming from the oil filler is normal up to a point. Chocolate malt gooo on the filler cap is a clue that you have too much blow-by.
Sitting so long the ring might not be lose and are gummed up and stuck. I put in Marvel Mystery oil in my gas! Yes gas. A pint in a tank full 3 or four times will lubricate the upper cylinder and hopefully loosen up your rings.
Have fun and in your case do an "Italian tune up" which is very fun.
