300 LB/FT Torque for axle nut?
I only have a torque wrench that has up to 150ft/lb. Does it mean that I would have to buy a new one with 300 ft/lb capability or find someone who would one?? Or is there a trick that I could use 150lb/ft torque wrench and use an extension to double it, huh?
I weight #200, so I put a 2 ft pipe on my breaker bar, and stand on the end of it. That should be close enough to 400 ft- lbs... and they seem to stay on after that...
fwiw,
