Best way to prep and paint trunk inside?
what is the best way to prep the inside trunk for painting. Does all of the rocker gaurd have to be removed and then re-applied?
that area presents a challenge for painting. Basically you want to create adhesion by increasing the surface area , that's why you sand prior to painting to create grooves (if looked under a microscrope, that is). I would use a coarse scotch brite (green or red) to roughen the surface. Make sure it is cleaned and degreased.
Removing the sound deading material is a pain in the butt and you will need a special schultz gun to reapply it. So if it is not broken leave it alone and paint over it.
Michael
