What I learned at Mid America, Exhaust failures
nbristow01
OK, whats with the exhaust on our cars. Several folks had mufflers fall off, resonators fall off etc. Lots of weld failures on the exhausts. It seemed most were cars with headers. i have a header and like to keep my exhaust on.
What are we all doing incorrectly?
Brad Fenn (AKA McGyver) wondered if adding a piece of the flexible stainless braided exhaust hose to the system, the kind often seen on front wheel drive cars, could help. Maybe added between the downtube and the resonator?
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
Yeah, it's really weird. I recently got under my '69 and found that the glass pack that is in the middle of the exhaust system had cracked almost all the way around! It was a really odd place of it to crack too. Luckily I caught it before it broke off while running down the highway or something! I think this one though is due to not having a mount near the middle of the system. The stress was just too much...
ClockWise MotorSports
'69 '02 Rat Rod O=00=O
'62 Chevy C10 w/SS 327
'63 Datsun 1200 pickup
'71 Datsun 510 Race Car
'70 Datsun Roadster
'78 Kawasaki KZ650 Street Cafe project
2010 Subby Forester (grocery getter)
lack of the correct support bracket with
all if it's spacers, rubber insulators,
special large washers to absorb the negative vibs.
poor installation alignment / assembly
lacking the 'correct' rear rubber donuts
with the nylon reinforcement inserts
to eliminate negative vibrations,
and to allow movement
poor quality parts
poor welding
'64 R27 250cc #383851 18,000m
If your running a header, flex pipe added between header and exhaust. I too had a similar breakage on a stretch of I-5 in Seattle. Had to find a coffee can at a convenience store. Haven't had a problem since running flex pipe. Almost everyone I know here that has a header runs one.
Squatch Pads
Lorena Texas
Exhausts on 2002's have to be braced to the transmission, and
you need to give them room to move.
I've had all the failures you note (including the radial cracks)
and the fix was simply to (wait for it)
let the tailpipe hang down further. (on an early car)
after that, all the suspension points for the muffler need to be good,
and leaving the 3- bolt clamp at the downpipe just snug, not hella tight,
is always good insurance. You can always tighten it a bit more,
but driving home with a coke can wrapped around the resonator sucks.
We did the flex pipe thing a while back- can it take twisting?
