Wiring Woes I: heater
Ferrance
In my restoration of a 1972 2002 BMW, I apparently rebuilt an old style heater (three-wire); however, my '72 harness has four wires for the heater. Assuming I can use three of the four wires, how should I wire it?
(My wires: blue/black; green/yellow; blue/red; brown ground. Old wiring diagram: green/white; green/red; brown ground.)
Three speed heater -
Here's the two speed -
Depending on how you'd like your three position switch to function, there are several ways to connect the switch to the blower.
The most direct hook-up would be to match your #1 & #2 switch outputs and leave your #3 switch output wire (blue/black) disconnected. This should give your switch the function of: OFF, LO, HIGH, and another OFF.
That's my best guess.
