FS:Pictures added;'84 121 head casting and flat top
jr02518
This is a solution that will keep you car running while you freshen up this combination.
The condition of the head should allow you to reuse everything short of the valve guild seals. The cam is stock, up grading it during the rebuild is your call.
The bottom end: block, crank, rods and pistons are available for inspection. Yes, everything is reusable.
This combination will provide a solution if your car is trailing smoke as you slow to a stop. If you have priced just the parts to rebuild a head this set-up will be a cost effective alternative.
The components are available in Riverside, CA for inspection.
$475 plus shipping from 92352 and 3% pay-pal.
David Barrish
