coil cover
Scott Sislane
Finally found a rubber cover for the coil. I feel so much better now. And heat shield socks on the ignition cables.... ahhh
http://cgi.ebay.com/ebaymotors/Coil-Cover-Austin-Healey-Lotus-Morgan-Bugeye-Sprite-MGA_W0QQitemZ230441035700QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item35a75b27b4
Actually, my Tii has e30 318 electronic ignition and the Bosch factory issued coil does have a rubber cover on the business end. Don't have the plug wire doilies however.
73 2002 Tii Sold
71 2002 Ti Vintage racecar
84 BMW 325 E-Prod racecar Sold
the two wires that connect to the + & - posts are under the cover. If you want the cover to also cover the boot of the ignition cable, you'd have to run the cable through and then attach the boot. Maybe the 320 cover opening is larger, to allow you to get the boot through the cover, but not on this one. I was more interested in getting the exposed + & - posts covered. It's as water proof as I will ever need like this.
Excuse my ignorance but what is that aluminum thermos with the filter thing next to the rad? Looks hi tech but wot is it?
Is fuel efficiency really what we need most desperately? I say what we really need is a car that can be shot when it breaks down.
- George Carlin
It's a catch can. The Valve cover vents into it, instead of the carb's air filter. Oil vapor collects in it, and you drain it every 2-3k miles.
