wiper wiring help - no existing harness...
epicyclic
Hi all,
I've scoured the forums for details on how to wire wipers from scratch and haven't found what I need.
I've got a 76 with the 4 position switch/stalk, the relay on the left in the picture below, a wiper motor... and zippo existing wiring. Thanks to http://www.my2002tii.com/wiper_how-to.htm for the relay photo!
I'm the superhappy new owner of Charley's M20 swap (http://double02.xanga.com), but now that the car lives in Seattle, I need some wipers where there had been none before.
Thanks for any help you have to offer!
Ok, you have no wiring harness connections?? It's possible to wire this up from scratch - I suggest buying the terminal ends - if available from BLUNT or supplier of your choice to make this easier to connect and troubleshoot - eventually. I've attached a 76 wiring diagram. If you wire up the components as shown, this should work fine. Be real careful when identifying the terminal connections. I would use color coded wiring and labels. You might also want to color code or redraw the circuts between components to make the wire-up easier. All terminals follow DIN standards. Best of luck with the project.
Dave
02wiringdiagram-76 w legend.pdf
Dave in Baltim02e Maryland USA
1969 2002 Sahara  Manila  :)
1966 WM300 Dodge Power Wagon-Valley Green; 1972 Airstream Overlander; 1997 JDM Honda Prelude; 2007 GMC Sierra 1500 tow vehicle to tow home all the above junk!
